Simulation report not following deformation scale
Brian.Greeson
Brian.Greeson
I have encounter a problem with the simulation report generator.  No mater what deformation scale I choose the report seems to pick it's own scale.  For example, I successfully create a simulation of a part.  I then change the deformation scale to "actual".  Fusion shows my simulation results with the selected scale, but when I create a report it reverts back to .5x or adjusted.  Am I missing an option somewhere to set the scale in the report or is this a known issue.
Thank you.
tomas.bujnoch
@Brian.Greeson That's a bug. I'll create entry in our bug tracking system for this particular issue. Hopefully it'll get fixed for the next update or release. Thank you for reporting.
