Revolve ellipse leaves profile behind
LMD001
LMD001
Hello Fusion 360 Team,
When Revolving an ellipse the ellipse profile stays visible, with a circle or a square this does not happen.
undefined
Thanks for looking at this.
Best regards,
Ludo
jeff_strater
Hi Ludo,
Yes, this is true.  It's not really the profile that you are seeing, but a model edge that the modeler has inserted.  I can check with the modeling team to be sure, but I think that what is going on here is that our modeling kernel does not have a simple representation for this kind of surface.  So, a revolved circle is a torus, and a revolved rectangle is a collection of  either planes or cylindrical faces, but there is no simple mathematical representation for a closed, revolved ellipse.  So, my guess is that the modeler defaults this surface to a periodic spline surface.  For reasons that are way over my head, mathematically, a periodic spline surface needs a break in it.  You will see the same thing if you revolve a spline profile.
Hope this helps explain what you are seeing.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Davidf01
I know you may have checked this but make sure the sketch light bulb is not selected in the browser. This will show the sketch all the time no matter what.
LMD001
Hello Jeff,
Thanks for the explanation. I just love mathematics!
@Davidf01 You are correct in pointing out the sketch "on" or "off" button, this can indeed be easily overlooked, but normally, when a sketch is consumed, Fusion 360 will turn the sketch "off".
Best regards,
Ludo
I get why Fusion 360 puts the edge there but is there any way to just hide that single edge?
Type a product name
