After the Jan 23 update, the Icon for the program is now broken for the shortcut in the program group. The shortcut points to this program.
C:\Users\ME\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe
If I try to change the icon to fix it, I get the attached error.
Solved by mikebJL63Z. Go to Solution.
Which icon is this? Can you show a screenshot of which icon you are talking about?
Sure. Attached. Taskbar and Quick Start.
It is annoying because you can't actuall see what program is running in the windows taskbar.
Those are the old icons, for the previous installation on your machine. Each update should replace the target folder, so the link points to a dead folder.
Have you tried deleting them and replacing them?
This shouldn't be happening, so we are glad you reported it. Has anyone else seen this? It would be helpful to know how wide spread it is.
Ok, it's an easy fix. Click on Start>>Right click on the old Fusion icon, Select Remove from this list.
Thanks for reporting this.
The start menu icon should refresh when Fusion 360 updates. So you do show an actual problem, but it's unexpected and hopefully rare.
Do you recall this happening before, from another update? Can you respond to this thread in a few weeks if it happens again? I don't want to let this go if it continues to be a problem.
Mine has been broken off and on since I started using Fusion in Sept. last year. This applies to my home computer, work computer, and shop computer. Windows 10.
When you say "Mine has been broken off and on ..." what exactly does this mean?
Are you saying that each update wrecks the Start Menu/task bar icon? Or that some updates fix the icons?
No problem. The issue is the "last known program location" C:\Users\THEUSER\AppData\Local\Autodesk\webdeploy\production. Windows maintains the last know icon location not based on the new "file name" but what it remembers (associated) what it was for this filename. It doesn't look it up every time because the icons have to be present "before" you run a program.
Once you delete the "bad" shortcut reference off the pinned "favorites" as I describe above, it will force Microsoft to look up the icon association for the filename or any new shortcuts and it will fix it "os-wide". The ICON is stored with the newest .EXE.
The main issue has been taskbar icons no longer launching Fusion after an update. There can be many reasons why this is. Here are some:
2. The icon is pointing to the FusionLauncher.exe file but INI is not correct.
3. However if #2 applies, you also need to find out why the INI wasn't updated as this is not normal behavior:
And there's:
4. The icon no longer shows the Fusion image.
Hope this helps but for anything that not's covered here or if you're still having trouble feel free to send me a note with your log files, screen shots, etc. to Kevin dot Baribault at Autodesk dot com. We'll get it resolved.
