Hello, I'm participating in the Autodesk Design Academy Challange. My project is finished but when I try to share it in the fusion 360 gallery I have problems with the images. You can see it here:
https://gallery.autodesk.com/fusion360/projects/juicer-lever?popupSNS=true
The images are cutted and I don't know why. In the attachments I put some photos of the project when I try to share it.
Ha. Never seen that menu entry 🙂
Nonetheless, I am afraid yout project is not done. If you take a look at your timeline it shows a host of icons highlighted in yellow. Those indicate warnings where Fusion 360 cannot reslove something without some user action. That would likely also explain why the "share to Gallery" ony shows the componentes in you design that don't have any problems.
It is usually best to fix these warnings during the desing process as soon as they show up.
Welcome to the Forum!
