Move tool, how to select mid point of the circle(after jan update)
Hi all, I am struggling to use move command after January 2017 update,  I need to choose mid point of the bolt, but I can not do this any more....
Before update, I could just move my cursor to the edge of circle and then pressing on CTRL  I could choose middle or any other point.
Please help!
josef.kucera
Hi @Anonymous
we really sorry about missing functionality in the Move command we have unintentionally introduced it in the last update.
It's discussed in many other threads for instance here: http://forums.autodesk.com/t5/design-validate-document/point-to-point-move-of-round-component/m-p/68...
We are working on the fix which will be in the next update.
Apologize again
Josef
Josef Kucera
Fusion QA
O.Tan
@Anonymous, at the moment you can use align. It's not perfect but that's what you can do for now.
@josef.kucera any idea when is this next update you're talking about? If it's going to be in a month time, I would suggest to temporarily roll back the Move update if possible.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
josef.kucera
Hi @O.Tan
definitely not a month, soon...
Josef
Josef Kucera
Fusion QA
etfrench
Try moving the Move/Copy dialog box so there are no selectable points between the center of the circle and the dialog.  After clicking on the circumference of the circle, the center should remain selected as long as you don't move the cursor outside of the circle.
ETFrench
daniel_lyall
Using the Aline tool to stick a bolt in a hole, It works fine for that.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
