I've found some problems using fillet seletions and variable fillets.
The first problem is while selecting a variable fillet sometimes the ends are opposite when you make the selections.
Here the blue arrow is the top Radius on the dialog.
Here the blue arrow is at the top of the box and the top radius in the dialog
This might seem like it doesn't matter but if you do a compute all the directions swap on 2 corners!
All small at the bottom
After compute all 2 edges swap to big at the bottom.
I've attached the file in a state where all the bottom fillets are small if you do a recompute 2 edges swap. I've tried editing the selections in the fillet feature but a recompute breaks it again!
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Hi @HughesTooling, thanks a lot for posting the issue here. It's definitely a bug of the variable fillet function in Fusion. I've logged a bug (FUS-22678) to track it. Hopefully, we can fix it ASAP.
Bruce (Fusion Development Team)
