Error in tutorial: "Coincident vertices may need to be welded together..."
- Mute
- Permalink
- Report
I'm get this error:
...when I attempt to save the spoon form created at the end of Mr. Sharma's lecture "Section 1, lecture 4 is entitled "Exploration and ideation using Fusion 360: Sculpting - spoon" in this udemy class:
https://www.udemy.com/design-for-innovation-using-fusion-360-water/learn/v4/content
After i do the thickening at the end of the lesson, and then try to close the form, the error occurs. The error also occurs if I attempt to save the form BEFORE doing the thickening.
If you look closely at bottom of the spoon bowl near the end of Mr. Sharma's lesson, you can see that he has the same symptom I have after the thickening (but before leaving the Form mode): There is a small hole there. The error doesn't appear in the lesson, though, because the lesson concludes without him exiting the Form mode.
Two questions:
- Does anyone agree that this is probably a Fusion 360 Bug?
- Is there any way to correct "cooincident vertices" problems, whether or not their creation was the result of a bug?
Thanks!
