Enter a construction point using XYZ coordinates
Message 1 of 47
I am reverse engineering parts and need to enter construction points at XYZ coordinates.
Points only move to a relative position, there are no absolute dimension fields.
Dimensions to 0,0,0 wont work because the points are not on the same plane.
I need these construction points for manual measurements or when using CMM.
TM
Replies (46)
Message 2 of 47
TrippyLighting
You can use the offset costruction plane command and then offset another plane from the first offset plane.
Message 3 of 47
Trippy, I have used that method for simple parts, but it is not feasible when there are hundreds of points at different Z heights.  When I'm using the Microscibe CMM, there may be thousands of points.
In other software packages, you can enter a XYZ location for points and then create construction planes from the points.
There should be a simple X_,Y_,Z_ entry form when making points.
TM
Message 4 of 47
innovatenate
Autodesk Support
Autodesk Support
I note that the status of the precise input Idea is set to accepted and that this feature enhancment is back-logged.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/precision-input-needed-to-position-g...
Manually entering in 1000's of XYZ coordinates seems like it would be prone to error and very time consuming. I mentioned a script in our previous discussions (below) you can use to auto-matically import points using a CSV file.
https://forums.autodesk.com/t5/design-validate-document/enter-point-location-using-xyz/m-p/5680038#M...
http://forums.autodesk.com/t5/design-validate-document/enter-point-location-using-xyz/m-p/5677580
Did you ever get a chance to try this out? I attached a custom script that was modified to create sketch points from the CSV file instead of a sketch spline.
The CSV file must be comprised of numeric values of the X coordinates in column A, Y coordinates in column B, and the Z coordinates in column C.
Below is a screencast showing how the default ImportSplineCSV import works.
Let us know if you have any questions.
Nathan Chandler
Principal Specialist
Message 5 of 47
Nathan,
  I have used the CSV import and it works, except for the fact that you get lost importing all the points at once.
Entering thousands of point would be very error prone, but, The Microscibe software is very intelligent, and it can insert a single points location into a cad systems XYZ form with a single click (if the cad system has a XYZ data form).
We do lots of work on complex engine cases, cylinder heads and stuff like that, we need to be able to enter points and make planes from a small section of the part, get the modeling straightened out and then move to the next section.
The idea has been sitting in the idea station for quite a while, I was just hoping there was a current viable solution.
TM
Message 6 of 47
innovatenate
Autodesk Support
Autodesk Support
Does the microscribe software have the ability to generate a mesh file format like STL or OBJ?
I know you can insert a mesh file into Fusion 360 and easily start to reverse engineer from a mesh file. This may be an alternate route you could take.
I was also noting these comments on the below microscribe page:
http://www.3d-microscribe.com/MUS%20Page.htm
If your application supports command line or dialog entry of 3D coordinates, this utility might already work or can be easily made to work with your application. If you would like your application to be supported by MicroScribe Utility Software, please contact us. MicroScribe Utility Software offers a way of interfacing your application to the MicroScribe with little or no change to your application.
Perhaps Mircoscribe would be able to create a script that is tailored for Fusion 360 that does exactly what you are looking to do. Fusion 360 does have a API resources to help automate tasks like this. I hope this information is helpful.
Nathan Chandler
Message 7 of 47
I'm not sure an stl would help our process, right now I am working on a 4 cyl 16 valve drag bike head, the valve angles will be altered to fit larger valves, and intake and exhaust ports will be relocated for increased air flow.  So, I'm not trying to make a surface map of the head, I need to pick off individual measurements of critical surfaces and design one step at a time.  once you start trying to bring in a surface map, it start to feel more like your working with a bitmap than a vector file.
My workflow in a different cad program---
Start with the piston side of an intake port-
pick 3 points at the top of the valve guide and make a plane and a 3 point circle
pick 3 points at the bottom of the valve guide and make a plane and a 3 point circle
create an axis through the center of the 2 3point circles for the center of the guide
off this axis create a plane 90 degrees at the valve seat height
I think you get the idea, there are hundreds of different planes and thousands of points by the time your done modeling a head.  Each of these points are entered into the cam software automatically by stepping on the foot switch on the Microscribe using the MUS software.  There is no manual data input.
The MUS software can interface with just about any software, but it cannot interface with Fusion because there is no XYZ input dialog for points.
The XYZ dialog seems like a tiny issue, but it is one (along with a couple others) that are preventing me from using Fusion as my front line software.
TM
Message 8 of 47
OK, another roadblock-
Make 3 random points on any plane
Move these 3 points to any random Z height, except for 0
Make a plane from these 3 points
pick the new plane and try to pick the same 3 points for a 3 point circle
The points will not snap, even though they created this new plane.  Is there a workaround for this?
TM
Message 9 of 47
PhilProcarioJr
@Anonymous
Select the 3 points when your in the sketch and hit the P key.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 10 of 47
PhilProcarioJr
@Anonymous
Actually there is a way to do this, although it's not ideal.
If you create a point at the origin 0,0,0 then hit the move key you can move that point to an exact X,Y,Z location.
Just make sure 3d sketching is enabled.
http://autode.sk/1Uyeq81
Phil Procario Jr.
Message 11 of 47
@PhilProcarioJr wrote:
@Anonymous
Great suggestion, but I've tried that.  The only point that snaps is the 0,0 on the new work plane, the rest will not.
TM
Message 12 of 47
ekinsb
Just to clarify what's actually needed.  Do you want a command that creates a single construction point but that allows you to specify the X, Y, Z coordinates of the construction point?  You want to enter the coordinates manually, point-by-point?  I believe a small script can be written to do that.
There's another alternative that doesn't use a script and is simpler that creating a lot of other construction geometry, but is still a couple of steps so it's not ideal either.
If you're capturing design history you need to first create a "Base Feature" using the "Create Base Feature" command in the "Create" menu.  The reason for this is that Fusion doesn't currently support work geometry in a parametric model that isn't based on other geometry.  You can't have a point that's freely positioned in space.  However, in a non-parametric model, or in a base feature you can do that.
In the non-parametric model or with the base feature active, create a construction point using the "Point at Vertex" option and either in the graphics window or the browser, choose the base Origin point.  Now you have a construction point at (0,0,0).
Run the "Move" command and select the construction point just created.  Now in the Move dialog you can specify the x, y, and z coordinates to reposition the point.
Brian Ekins
Mod the Machine blog
Message 13 of 47
Yes, that is  exactly what I need.    A script would be great.  I'll try your other ideas.
TM
Message 14 of 47
@ekinsb
  When I follow these instructions, the point that is created is grounded to the base feature.  I've tried every filter and type of selection, but the point cannot be moved without moving the base feature.
TM
Message 15 of 47
ekinsb
Here's a Screencast that demonstrates the workflow.  The base feature needs to be active anytime you want to add a new point.
Brian Ekins
Message 16 of 47
@ekinsb
I do not have the create base feature button that you select at 0:09.  What is it?
TM
Message 17 of 47
ekinsb
The Base Feature command is only available when you're capturing design history (parametric modeling).  It lets you have an island of direct modeling within a parametric model.  If you're not capturing the design history (direct modeling), which is sounds like this is the mode you're in, then you don't need it and can skip the Base Feature steps so it's a simpler process.  Basically, create the construction point on the origin point and move it to the desired location.
Brian Ekins
Message 18 of 47
innovatenate
Autodesk Support
Autodesk Support
This link shows how to enable and disable design history in a design. This is how you can toggle between a parametric design and a direct modeling design.
http://knowledge.autodesk.com/article/How-to-switch-between-a-parametric-or-direct-modeling-environm...
Hope that helps!
Nathan Chandler
Message 19 of 47
@ekinsb
  OK, Now it makes sense.  This is starting to prove that it may be possible to do what I need, but there are just too many steps involved to make it usable.  Could these steps be put into a script?   How would a person start designing this script?  Are there any examples that could be modified?
TM
Message 20 of 47
ekinsb
There's a Fusion update coming this weekend that adds base feature support in the API.  With that I'll be able to write a script that will work for both parametric and direct modeling models.  I'll post an update here when the script is available.
Brian Ekins
