Looks like it cuts with the extrude but then when I click ok, no cut is visible. A little baffled on this one.
I can share the file...
Solved by eric.strebel. Go to Solution.
If you share the file I will take a look at it.
Phil Procario Jr.
Owner, Laser & CNC Creations
Hi @eric.strebel,
Please share the file with me. colin.smith@autodesk.com.
Thanks!
Colin
OK, I figured it out. I did not make the sketch on the actuall object that I wanted to cut, so it made a thin little skin that made it look like nothing was cutting. Thanks for the quick posts. All good here now.
@eric.strebel, thanks fo the follow up.
Happy modeling.
Colin
