I have two spheres (regular bodies) placed arbitraily in 3D space (they are unaligned in any axis).
I am trying to connect them with a simple primitive column.
Is that possible? Or even just draw a line between their centers?
Ideally I'd like to have a curved pipe between their centers, but I'll settle for a column.
Thank you,
Daniel
Solved by TrippyLighting. Go to Solution.
Sure!
Draw a Cylinder and move it so it will interset with both Spheres. And use "Modify->Combine".
There's also no need to settle for a stright column. You can sweep a profile along a curved path, a spline for example. Then use "Modify->Combine" to combine the bodies into one.
Thank you for the quick reply!
I wound up doing the following:
Creating a new Sketch
Creating a spline with endpoints centered inside the two spheres
Ending the sketch
Rotating the view and then moving individual spline control points in 3D space with Modify->Move
Using Create->Pipe to create a new object along the spline path that connects the two Spheres
Using Modify->Combine
Worked great!
Thank you,
Daniel
