Again, as the title reads: Is it possible to change the fillet of two lines in a 3D sketch in retrospect? Of course, the best would be if I could drive the fillet by a user parameter, but I have tried and this does not work unfortunately...
Many thanks in advance!
At this time, you are not able to create dimensions for a 3D sketch. My suggestion would be to create dimensioned points with other sketches first and then create a 3D sketch using those points so that you can go back and edit the dimensions on the points.
Cheers,
Mike Prom
Same roadblock here. I'm trying to model a bicycle handlebar which has an upsweep and a backsweep, so I'm using 3D sketches to do that. The last step is to use the Loft tool to create a butted pipe. Now, I need the bends in the handlebar to be smooth so I first need to add a couple of fillets in the sketch so the loft bends smoothly, but one of the fillets is not on any of the sketch planes, but rather in 3D space, as shown below, and there's no way to edit the dimension (in fact it doesn't even show up anywhere in the Parameters window):
Are there any new plans to address this limitation? Thanks
