For some reason my browser is now in it's own floating window. How do I get it back so it's not in it's own window?
Solved by AnandSomani. Go to Solution.
Hi @SGoldthwaite,
You can select the browser window by its title and drag it to the very end of the left side. You can see a green highlight there suggesting that it will snap there.
Once snapped, it will look like it used to.
Thanks.
I am not on my Fusion Station at the moment so canot post a screenshot, however, there is also an option or menu entry somewhere that allows you to reset Fusion to the original layout.
still cant find it...
@AnandSomani wrote:Hi @SGoldthwaite,
Thanks.
Hi @mustafa_044,
Welcome to Fusion 360 Forum! 🙂
The green highlight should show up when your cursor reaches the left-most side of the window. Please try dragging the browser window until your cursor reaches the end.
However, if that still doesn't work for you, you can always go:
File Menu -> View -> Reset to Default Layout
Thanks.
