What I am saying is:
1. I would NOT publish new fresh DWF files from the DWG files and mark them
up again using Autodesk Design Review. Though Autodesk Design Review has a
friendly user interface, it would be painstaking to try to recreate the same
markups from the RML using the user interface of Autodesk Design Review.
Instead you should:
1. Publish DWF files, where you don't have an existing DWF file, from your
DWG files using the Sheet Set Manager or a batch process.
2. For DWF files that you have which have no markup or markups from Autodesk
Design Review, keep as is.
3. For DWF files that have markup from Volo View, load them into Autodesk
Design Review and print to the DWF Writer for 2D. You should get a new DWF
file that has the geometry from the DWG and the markup from the RML. The DWF
file will be bigger than a traditional DWF, you may lose the layer info, but
at least you can see the markup.
wrote in message news:5524137@discussion.autodesk.com...
One last question 🙂
"I would not painstakingly recreate them in Autodesk Design Review"
That's what I'm after, but I think your referring to the DWG format and not
the existing DWF's from Voloview that were created! 100 or so...?!?
What's the best way to translate them so that they can be viewed in Design
Review and not show mis-alignment between the graphic and the mark-ups?
