I would like to know if there is a way to control view settings from the API. I would like to set the fidelity, performance value through code if possible.
Also, I have not been able to come across a way to hide the ribbon completely. Is this possible?
I see that there are a number of methods/properties available with the dwfviewer object that are not part of api documentation. May be, all I would need to do is to know the relevant methods/properties. Please let me know.
As a note, I am using vb.net, visual studio to integrate a dwf viewer in windows forms.
Thank you.
Thank you for your questions.
To hide the ribbon, you can refer to the solution which was mentioned in the post:
Any other specific API questions please let me know.
I referred to the solution in that post. Setting "_ViewerParams = ?RibbonDisplayMode=RibbonNotShown" property in windows form properties for the axCeExpressControl does not work.
Thank you for your feedback.
Please insure that there is no space character in '_ViewerParams' field.
By the way, to hide both Ribbon and Canvas toolbar, you can set '_ViewerParams' as:
?RibbonDisplayMode=RibbonNotShown&?CanvasToolbarEnabled='false'
Attach a sample application which works on my machine.
Hope that helps.
Herbert,
Thanks, it worked. As you suggested, may be I was overlooking a space earlier.
