I have a Form in VB.net with the DWFviewerCtrl.
As I load some DWFx file and export the MarkUp Properties via the IAdMarkup Interface, everything is working fine.
However, if I change the MarkUp in canvas(length, position, etc) the dwf object seems not to register this event and let me export the old properties(loaded with the DWF file upload).
Is there any possibility to update the parameters without the need to file:save-close-open, resp.MarkUp:delete-create procedure?
I tried DWFViewer.Update() but that doesn't work...
thx in advance
Did anyone found a solution already to programmatically change markup-properties and write them back to the file ?
