I have a couple of dwfx files exported form Revit that won't open. It seems like the files that won't open are 16000 kb and higher, since the files that are smaller than that open fine. I was just wondering if anyone knows how to fix this, in design review or revit.
Thank you for your feedback.
Could you please post a DWFx file that cannot be opened in Design Review onto our ftp? So that I can try to reproduce this issue.
Please let me know once the file is posted.
LoginID : discussion
Password: ADR2009CST
Please open the Windows Explorer to upload your file, according to the attached picture.
I have the same problem - I think my DWFx files are damaged. Is there a way to retrieve them? I've got days of comments on the file.
No, the damaged file cannot be retrieved.
we have the same problem with exporting DWFX files from Revit. Especially when the colorscheme is active. Is this the reason? When we make a copy of the view and put them in a new sheet then it works fine for a while. Unfortunally the problem keeps coming back. We work in Revit 2011...
Thank you for reporting this problem
This is a Revit publisher issue. Other discusson groups focus specifically on Revit. I suggest that you can post your question in those groups.
Please try the follow links for your convenience.
Autodesk Revit Architecture
Autodesk Revit Customer Gallery
Please let me know if I can be of any further assistance.
Hi Herbert,
is there any problem for opening big files?
I have a similar issue. The properties and model tree doesn't show anything when I have a big file.
The file is too big for attach.
Can you provide ftp for that?
Thank you.
