I downloaded Trueview.
I want to open a 2014 dwg drawing and convert it to 2000
When I select the file type "all" and click on the dwg file I get the message drawing is not a DWF file.
So the program is a DWF viewer but when I downloaded it the file was called "trueview"
Is Trueviw part of DWF viewer, why does it not work with the file?
Wrong product, you want:
DWGTrueview 2014 download links can be found in this post:
http://forums.autodesk.com/t5/Installation-Licensing/TrueView-download/m-p/4427763#M68123
DTV 2015 64bit Download is here:
http://download.autodesk.com/esd/dwgtrueview/2015/SetupDWGTrueView2015_ENU_64bit.sfx.exe
