Not sure if this is the right place for this but.....
I had an app that I wrote using XP Pro 32bit , VB 2008 Express using the AdView.dll. This app worked great.
I then received a new computer using XP Pro 64 bit, VB 2010 Express. Tried opening and migrating this same app and it had errors. So I started trouble shooting. I opened up a blank app and inserted the DWF control onto the new form and VB 2010 Epress crashed. I have wrote code for a work around using Process.Start(filePath, "DesignReview.exe").
Just to open the DWF files but...
I would like to incorporate this control straight into this app so I dont have to open an instance of ADR or actually I have set the default program to iexplorer to open the DWF files. It opens quicker then ADR.
Any help would be appreciated. Thanks in advanced.
Thank you for reporting this issue.
Please to try the solution provided by BachmannGmbH in the post:
Hope that helps.
