Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Trouble with adview.dll in VB 2010
1 REPLY 1
cory.seifert
960 Views, 1 Reply
Not sure if this is the right place for this but.....
I had an app that I wrote using XP Pro 32bit , VB 2008 Express using the AdView.dll. This app worked great.
I then received a new computer using XP Pro 64 bit, VB 2010 Express. Tried opening and migrating this same app and it had errors. So I started trouble shooting. I opened up a blank app and inserted the DWF control onto the new form and VB 2010 Epress crashed. I have wrote code for a work around using Process.Start(filePath, "DesignReview.exe").
Just to open the DWF files but...
I would like to incorporate this control straight into this app so I dont have to open an instance of ADR or actually I have set the default program to iexplorer to open the DWF files. It opens quicker then ADR.
Any help would be appreciated. Thanks in advanced.
1 REPLY 1
herbert.he
in reply to: cory.seifert
Thank you for reporting this issue.
Please to try the solution provided by BachmannGmbH in the post:
http://forums.autodesk.com/t5/Autodesk-Design-Review/ADR-2011-Api-amp-VB2010-Express/m-p/2900418/hig...
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
