Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
This software is HIDEOUS for Revit 3d models
7 REPLIES 7
Message 1 of 8
RevitUser123
1778 Views, 7 Replies
It is dark, the shadows suck, and many other issues.
7 REPLIES 7
Message 2 of 8
BIMTIM
in reply to: RevitUser123
If you need your 3D model to look 'nice' use Showcase.
This is designed for design review, not really presentation. Try Playing with the lights, not that there are many options. 'No lights' Works well for darker revit models, headlamp, is a waste of time.
Message 3 of 8
a.a.adryan
Hello
Are you using Showcase 2012?
If you are, I would highly recommand trying Showcase 2013 SP2.
Autodesk made massive visual improvments in Showcase 2013.
I attached an image of the Revit sample scene that I imported into Showcase. Have a look
I would like to see what you have (a few pics), maybe I can assit you by offering a few suggestions on how to improve the visual quality of your Revit geometry in Showcase?
Message 4 of 8
RevitUser123
in reply to: a.a.adryan
I heard about this. This requires the Design Suite so you can link the Revit model to showcase (cannot do with Suite). Also. Can showcase handle large Revit models, or even a site with linked models in it? Before with 2012 I had to export a fbx file and it would be horrible with resources. Respectfully, Corbin S.
Message 5 of 8
a.a.adryan
You do not need to get the design suite. I believe that you can purchase Showcase on it's own
http://store.autodesk.com/store/adskus/en_US/buy/Autodesk_Showcase_2013/productID.247425400?mktvar00...
Also, you can link the Revit Model without the suite. Here is how:
1) Export Revit geometry into FBX
2) Import FBX into Showcase
and anytime you re-export the FBX and replace the one that you used to import into Showcase, Showcase will inform you that you need to reload the geometry in the import status
To answer your other Question. Yes, Showcase does handle large data sets. However to get good performance you have to combine the geometry and break the link to the originating FBX file
Here is a tip:
Showcase ships with a plug-in called "AutoGroupCustom.py"
Running this plugin will automatically group and combine your scenes geometry to make it run nice an smooth, but beware that this would break the link.
You'll go from having thousands of separate objects to only a few hundred, which is more manageable.
Message 6 of 8
narlee
AutoGroupCustom.py must be integral to the Revit Suite Workflow path, because using that seemed to improve the smoothness of the walkthru quite a bit.
Message 7 of 8
narlee
in reply to: narlee
A.A. Dryan,
1) How do I change/can I change my little screen name to something else (it is showing as "design").
2) How do I run that plug-in. I can't seem to figure it out.
Thx,
Message 8 of 8
narlee
in reply to: narlee
btw, gigantic improvement over prior showcase.
