Is there a way to reverse the mouse wheel zoom in/out function, similar to the AutoCAD command ZOOMWHEEL or changing the setting in Application Options for Autodesk Inventor? I searched the forum and could not find an answer.
Solved by rkmcswain. Go to Solution.
I would also like to know the answer. It feels like it has been setup wrong.
Yes, thank you.
I couldn't find those options at first. They weren't on the ribon or the File menu. Had to right mouse click the view of an open document.
