Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Puplish Multi Sheet DWF from individual DWFs
11 REPLIES 11
Message 1 of 12
281 Views, 11 Replies
I really need to be able to create a multiple sheet DWF from Individual DWFs. Or have the ability to combine DWFs to create one Multisheet.
Any Ideas?
11 REPLIES 11
Message 2 of 12
DWF Composer will let you do this with drag and drop. "clarkm2" wrote in message news:27577107.1110316704308.JavaMail.jive@jiveforum2.autodesk.com... >I really need to be able to create a multiple sheet DWF from Individual >DWFs. Or have the ability to combine DWFs to create one Multisheet. > Any Ideas?
Message 3 of 12
Thanks! That is GREAT!
Message 4 of 12
kch214
I am trying this same thing with the 30-day trial version of Composer. When I go to scroll thru the pages using the arrows, it jumps around (sheet 1, 4, 7, 13 of 16, for example). It does not go sequentially. If I send the same DWF to a co-worker with a 30-day trial version, it does the same thing but different pages!!! Help! I am really interested in purchasing several copies of this program if I could just figure out this glitch. What am I doing wrong? Or is it b/c of the trial version?
Message 5 of 12
It sounds like a bug in DWF Composer 1. I had a user who had a similar
problem that was fixed in DWF Composer 2. In a short while the trail will be
updated from DWF Composer 1 to DWF Composer 2.
wrote in message news:4846440@discussion.autodesk.com...
Message 6 of 12
kch214
How soon can I look for Composer 2????? Also, will I be able to do a trial of Composer 2 even though I am currently trying Composer 1?
Message 7 of 12
Composer 2 is out now! It's got some great new features. I have already ordered 12 copies, just make sure when you place your order you specify that you want composer 2 not 1.
Message 8 of 12
If you are going to do the Trial of R2, you will have to uninstall R1.
Composer R2 is shipping now. The Trial version is not yet released, as
stated in other threads... Soon, it will be available soon.
wrote in message news:4847000@discussion.autodesk.com...
Message 9 of 12
kch214
My Composer 1 trial run is over...is the Composer 2 available yet for trial??? I need to purchase soon but am leery if 2 doesn't fix my problems.
Thanks.
Message 10 of 12
Soon, is all I can say. Keep checking back on the Autodesk web site and I'm
sure someone will post a note about it in this newsgroup once it's
available.
wrote in message news:4879756@discussion.autodesk.com...
Thanks.
Message 11 of 12
brett481
Let me apologize in advance if this is a silly question, but what specifically do you drag and where do you drag it to. For instance I have 9 individual dwf's saved that I want to send out for review as one file. Thanks for the help.
Message 12 of 12
You can open 2 DWF files - each one in its own instance of Autodesk DWF
Composer. You then go to the list of sheets, select them all, and then drag
and drop them to the list of sheets in the other instance of Autodesk DWF
Composer. With the Autodesk DWF Viewer that is in beta now, you will be able
to mutiselect DWF files, right click, and select Merge. You could then use
Autodesk DWF Composer to arrange them as desired.
wrote in message news:4998161@discussion.autodesk.com...
