Hello veryone,
I have such problem, when i run my aplication on windows vista without ADR 2011 instaled on it, my aplication crashes. When I instal ADR 2011, it still crashesh.
What else is needed for running aplications with ADR control?
Thank you for your question.
You just need install ADR for running applications with ADR control.
If you can launch ADR application, maybe there is something wrong with your own code. Please provide more detailed information for us to investigate.
Any further questions please let me know.
invastigated further, and yes adr must be installed on computer 🙂 everything works fine on 32 bit version of vista and xp. But problem is with 64 bit versions of vista and xp. Maybe there is some difference from where references are taken? Last error yesterday was that class cannot be registered. Is any difference making windows form with adr in 32 bit system and 64 bit system? And what the best method is to check in form if adr is instaled on computer?
to be more precise i get - Class not registered {"Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))"}
ivestigation showed that windows form compiled with setting targeting X86 platform gave positive result, and application is now running in x64 bit version of windows
Thank you for your feedback.
Please let me know if I can be of any further assistance.
Hello, if you can, please comment this problem:
I have one problem. In attached revit family, 3d view is empty. After export to DWFX, design review 2011 crashes while opening this exported file. To be more specific am using windows forms and ADR component. Is there any solution to such error? Can I check with ADR api if view (section) can be opened noramly?
Please upload the exported .dwfx file to this thread for me use to investigate.
here is family and exported dwfx file
It's a Revit publisher issue, this exported dwfx file contains invalid resources ("kzRole_ContentPresentation"). I have reported this defect to Revit team.
Also, can ADR 2011 run inside Revit? Now when call external command with form, revit crashes after closing this form. Is it possible to run ADR inside revit?
Hi, I'm having the same exact problem, however, I am using Windows 7 x64. What was the solution for this problem?
