Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
problems installing "downloaded Autodesk Design Review 2012"
4 REPLIES 4
vickyd
1887 Views, 4 Replies
I've tried looking through the forums for help but cannot find answers to my problem. Can any one help me?
Operating system Windows Vista 64-bit - desktop computer
Attached screenshot of error 2738 & log file...
Any help would be greatly appreciated 🙂
4 REPLIES 4
wube
in reply to: vickyd
Cause
This error message indicates that the VBScript engine is not currently registered on the machine where the install/uninstall is taking place.
Resolution
The VBScript engine can be quickly registered by following these steps:
Run Command Prompt as administrator:
Start Menu -> All Programs -> Accessories
Right click on Command Prompt and select Run as administrator
Run the following command:
If you are using 32-bit version of Windows:
Type cd %windir%\system32 into the Command Prompt and hit Enter
If you are using 64-bit version of Windows:
Type cd %windir%\syswow64 into the Command Prompt and hit Enter
Type regsvr32 vbscript.dll into the Command Prompt and hit Enter.
Ben Wu
SW Engineer
PSEB-GE-ACRD
vickyd
in reply to: wube
Hi Ben,
I tried the Resolution of:
Tried installing ADR 2012 again with no luck?  Then I thought maybe a reboot after the command change & tried to install again with no success?  Same error comes up?  I've attached the screenshot & the updated log file....any thoughts?
This is really frustrating, why such a simple thing becomes so involved?
Help please Smiley Sad
wube
in reply to: vickyd
Thank you for your feedback.
Please try to uninstall the old Design Review from your machine manually.
Then restart the installation of Design Review2012.
Ben Wu
SW Engineer
PSEB-GE-ACRD
vickyd
in reply to: wube
I finally solved the problem...turns out it was "McAfee" anit-virus software which was causing the problems!  I uninstalled McAfee and installed both "ADR 2012 & Dwg True View" on my machine! Smiley Happy
