Design Review
Design Review
0 Kudos
Post 1 of 8
Problems encountered during DWF import
1720 Views, 7 Replies
08-03-2009 10:20 AM
I have installed Autocad 2010, Design Review 2010 and TrueVue 2010 on the same PC. Until today, I was able to assign DWG files to open in Design Review. (with TrueVue converting to DWF). Now, when I try to open a DWG with DesignReview I get the error:
"DWF Convert Error - Problems encountered during DWF import" What I have done wrong?
Allan
Employee
2 Kudos
Post 2 of 8
Re: Problems encountered during DWF import
08-03-2009 10:38 AM in reply to: mcdakk
Are you using a 64-bit system?
Currently open DWG files in ADR only works on 32-bit platforms.
Kevin
Kevin Moore
Test Development
AutoCAD
0 Kudos
Post 3 of 8
08-03-2009 10:43 AM in reply to: mcdakk
No 32 bit. Like I said, it was working fine until today. Another engineer brought it to my attention, because that is the only way he views DWG files, thru ADR. So, I tried uninstalling ADR and ATV and re-installing on my PC. Same error.
Employee
2 Kudos
Post 4 of 8
08-03-2009 01:16 PM in reply to: mcdakk
I remember a co-worker having a similar problem. He opened a DWF (not DWG), exited ADR, and restarted. The problem never occurred again. Try simply opening a DWF and DWFx file in ADR, then restart ADR.
I will look into this more later.
Kevin
Kevin Moore
Test Development
AutoCAD
0 Kudos
Post 5 of 8
08-04-2009 04:38 AM in reply to: mcdakk
Still does not work.... They way I understand it...if you have ATV2010 and ADR 2010 on the same PC and you try to open a DWG with ADR, it first looks for ATV, converts the DWG to DWF, then opens that DWF in ADR. Something is not allowing a proper conversion of the DWF.
Product Support
18 Kudos
Post 6 of 8
08-05-2009 07:09 AM in reply to: mcdakk
If you have TrueView installed, are you able to open the DWG's in that program? TrueView is meant for opening DWG's, while Design Review is meant more for DWF's, even if it has the ability to open DWG's. Opening DWG's in TV instead of DR might be your best solution.
As for the error you are seeing, our development team is currently investigating these errors to try and find the cause. In some instances, uninstalling DR and TV and then reinstalling them has resolved the issue. You may want to try this to see if it fixes it for you as well.
Shawn Niles
Autodesk Product Support
Shawn Niles
New Member
0 Kudos
Post 7 of 8
01-07-2013 02:22 PM in reply to: Shawn_Niles
I have packaged ATV 2013 for deployment but it is not being detected by ADR 2011/2012 as being installed so ADR will not open DWG files. 2011 works fine but 2013, no go...
Error message is 'DWF Convert Error - Problems encountered during DWF import'. There isn't much on this is the release notes or the AutoDesk forums.
New Member
0 Kudos
Post 8 of 8
09-05-2014 08:31 AM in reply to: Shawn_Niles
Did your team figure out the issue? I am trying to open a PDF file in ADR and I am getting the DFW import error.
