Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Problem orientation cube Inventor2010>ADR
1 REPLY 1
609 Views, 1 Reply
When i export a .iam to dwf, the orientation of the cube is differtent in the dwf.
The origin form the .iam is good, also the orientation of the cube is o.k. (top is the topview)
When I use the option (right click on the cube) ''reset front'' the cube its also o.k.
Why can ADR not copy the right orientation?
In ADR is the topview of the model > front (cube)'
Can someone help us?
1 REPLY 1
springai
Thank you for reporting this issue.
We had logged a defect ID 1028174 against this issue. We're considering to fix it in further releases.
-Spring
Spring Ai
Fusion 360
