Scott,
I have also discovered that I do indeed have a "mirror image" checkbox
that DOES allow the image DWF to print properly, but it will also print
"normal"( Published IDW's from IV) DWF's mirrored.
I suppose I could print seperate "image" pages with the mirror function
on, then switch it off and print the drawing sheets independantly.
I will try printing with several different machines in the next couple
of days and see if I find any other mirrored prints.
At least it seems to be local to my setup. Without this wonderful
(fast/easy) way of collaborating (marking up images-genius functionality
by the way!!) I was starting to get the "half-baked" feeling about
Composer.
I will continue to use this functionality but make sure recipients are
aware that if they are lucky enough, they might be able to produce a
mirrored print.
Thanks for looking into this for me.
QBZ
"SLillibridge (ADSK)" wrote in message
news:14943034.1091560030760.JavaMail.jive@jiveforum2.autodesk.com...
> Hi Quinn,
> I've been looking into the print issue you reported and so far have
not been able to reproduce the image mirroring problem that you are
seeing. I don't have access to an HP DeskJet 6122, but I have
successfully printed the file to an HP DeskJet 1220C, an HP Business
InkJet 2230, and to an HP LaserJet 9000 PCL6 with no problems noted. In
all cases I used the default Print settings (Full Page, Letter,
Landscape, Best Fit). Is there anything unique about the Printer
configuration that you are using? (For example, under Properties for
the HP DeskJet 6122, are there any custom features that are turned on?
My DeskJet 1220C has a 'Mirror Image' feature that is off by default but
which can be configured.)
> Thanks in advance for any additional information you can provide.
> -- Scott Lillibridge, Autodesk Viewers QA
