So far, I've struck out with all the suggestions.
I've tried copying the Setupdesignreview.msi to the C:\windows\downloaded
installations folder and tried to uninstall from there: No luck
I've tried uninstalling from the CD: No luck
I've tried using the MSIEXEC /x setupdesignreview.msi {program code}: No
luck (I don't know what the program code is but i opened the
setupdesignreview.msi in a texteditor and tried to use all the codes within
braces that appeared in the file in the hope that one of them would work).
I hope someone has another suggestion to try, if not, my next step is to
waiting until my Acad2008 arrives and uninstall 2007, purge all the
directories where anything Autodesk resides, and purge the registry of any
reference to Autodesk, Autocad, dwg, dwf in the hope of cleaning out the
system and trying to install fresh. That or reformat .... NOT!
Thanks again for all the suggestions and if any other suggestions are out
there, I'd be greatful to hear them.
