Il looked everywhere but can't seem to find a satisfying answer. My question is quite simple: How do we determine the default pivot point (in AutoCAD) that will be used by Design Review? I know that you can change this pivot in Design Review with the "Center" function, but my DWF will be embedded with no menus (and I don't expect my viewers to use the "Center" function even if it was available).
I tried a simple 3D model, centered at 0,0,0 and exported it as a DWF (3ddwf command). In the resulting DWF, my pivot point is very far from the model and not even at 0 altitude on the Z-axis. Am I doing something wrong? Any kind of help will be appreciated.
Thank you for your feedback.
This should be an AutoCAD publish issue, could you please post your problem at AutoCAD Discussion Groups?
-Spring
