Design Review
Member
koobcat
Message 1 of 2 (557 Views)
Pivot!
557 Views, 1 Replies
10-07-2011 06:30 AM
Il looked everywhere but can't seem to find a satisfying answer. My question is quite simple: How do we determine the default pivot point (in AutoCAD) that will be used by Design Review? I know that you can change this pivot in Design Review with the "Center" function, but my DWF will be embedded with no menus (and I don't expect my viewers to use the "Center" function even if it was available).
I tried a simple 3D model, centered at 0,0,0 and exported it as a DWF (3ddwf command). In the resulting DWF, my pivot point is very far from the model and not even at 0 altitude on the Z-axis. Am I doing something wrong? Any kind of help will be appreciated.
Employee
springai
Message 2 of 2 (546 Views)
Re: Pivot!
10-09-2011 12:43 AM in reply to: koobcat
Thank you for your feedback.
This should be an AutoCAD publish issue, could you please post your problem at AutoCAD Discussion Groups?
-Spring
Spring Ai
SQA Engineer
PSEB-GE- ACRD PSEB
