Design Review
Design Review
Active Member
0 Kudos
Post 1 of 10
Open dwg in Review
629 Views, 9 Replies
10-12-2011 07:21 AM
I have installed the last version of Autodesk Review (12) and I would open the dwg file by Autocad 10. This does not appear possible, because it call for DWGtrueView. I have observed that in the Option there is not the label for dwg setting, as (I think) in the case that DWGtrueView is installed. However, this is not the case, despite once it was installed and then removed. Do you know how is possible to open a dwg without installing also DWGtrueView? Thank you in advance.
P.S: I have already attempted to reinstall Autodesk Review, but the problem remains..
Ciao
Employee
0 Kudos
Post 2 of 10
Re: Open dwg in Review
10-12-2011 07:14 PM in reply to: giordandue
Thank you for posting.
The issue you encountered may caused by:
  1. We only support open DWG file using AutoCAD 2011 and 2012 in Autodesk Design Review 2012.
  2. If AutoCAD has been installed on 32bit platform, the DWG Settings tab should appear in Options dialog.  I guess you were working on 64bit platform, 64bit AutoCAD is not supported for DWG importing in Design Review, and there will NOT have DWG Settings tab in Options dialog on 64bit platform machine, you have to install DWG Trueview for converting DWG file.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
0 Kudos
Post 3 of 10
10-13-2011 12:14 AM in reply to: giordandue
Thank you for your answer. I tried to follow your suggestion by installing dwgTrueView, but I encountered another problem: when I launch the program a fatal error message occurs that it requires a video resolution higher than 1280x720. I have 1920x1080 (and the big characters are setted). I have Win7 63bit installed. Thank you again for you support.
Employee
0 Kudos
Post 4 of 10
10-13-2011 12:22 AM in reply to: giordandue
I did not meet that error before, are you using DWG Trueview 2012 64bit installer?
You can download it from (make sure to choose 64bit version):
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=9078813
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
0 Kudos
Post 5 of 10
10-13-2011 01:00 AM in reply to: giordandue
Yes, I tried both the last versions (12), in the first time the 64bit and then the 32bit as well. With the last one, the error message remains, but it seems possible after some time to open the file, that appears strongly incompleted.
Incidentally, I have read in the discussion groups that a similar error message have been registered by some other users (maybe for different causes?). Any suggestion? Thank you
Employee
0 Kudos
Post 6 of 10
10-13-2011 01:44 AM in reply to: giordandue
I cannot reproduce it since we do NOT have test machine with 1920x1080 screen resolution right now.
This is a DWG Trueview installation issue, I will forward the problem to DWG Trueview experts, stay tuned.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
0 Kudos
Post 7 of 10
10-14-2011 06:33 AM in reply to: giordandue
Hi Dicky,
I remained tuned but no answer from your colleagues trueView experts.. Do you have some possibility of insisting with them a little more? Thank you in advance, Giordano
Employee
0 Kudos
Post 8 of 10
10-14-2011 10:58 AM in reply to: giordandue
DWG Trueview expert have not replied to me yet.
Could you please leave an email adress so that I can keep you in that email loop?
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
0 Kudos
Post 9 of 10
10-14-2011 11:05 AM in reply to: giordandue
my e-mail is giordandue@alice.it
Thank you for you help
Giordano
Active Member
0 Kudos
Post 10 of 10
10-14-2011 03:22 PM in reply to: giordandue
I realized that the problem is origined by the setting of character (as I said, given my very high resolution, I have "big character=150%). Removing this setting, the DWGtrueView is launched without message error about the required resolution. However, I suspect that some directX problem occurred (I had the version 11, while trueView install 9runtime), because later it was not more possible to come back to the original setting. In particular, the Notebook changed all the type of characters to a "very basic" format and the ClearType option does solve the problem. Despite I tried to increase the dimension of character to 160 and even 180% the characters remains relatively small and thick. Consequently I restored the PC to the safe point before the DiectX installation and all is now again ok.
