Design Review
Design Review
Member
0 Kudos
Post 1 of 4
Open DWF inside Internet Explorer 9
1975 Views, 3 Replies
05-03-2011 01:27 PM
I have an issue with Internet Explorer 9 and Design Review 2012 on a machine with WIndows 7 64bit.  When I try to open a DWF file it asks me what I want to do.  Open, Save, or Save as.  Then it asks me to Open, Save or Cancel down at the bottom of my window.  When I click on open it opens the file by actually opening Design Review program and not inside the browser.  Can this be fixed?
New Member
0 Kudos
Post 2 of 4
Re: Open DWF inside Internet Explorer 9
08-22-2011 09:43 AM in reply to: cakitzmann
I am having this same problem. Did you ever find a fix for this issue? The plugin works fine after I install it but after I reboot the machine it does exactly what you mention.  If I uninstall and reinstall it will work again until I reboot.
Member
0 Kudos
Post 3 of 4
08-22-2011 09:51 AM in reply to: okstate
I have not found a solution.  I have gone back to using IE8 unitl I or some does find a solution.
New Member
0 Kudos
Post 4 of 4
08-22-2011 02:08 PM in reply to: cakitzmann
I found a work around for this problem.  It seems like it is a firewall related issue but I'm really not sure what it is specifically.  When I opened up the firewall completely it worked fine.  I found the workaround to be running the website in 32 bit Internet Explorer instead of the default 64 bit.  I just made a shortcut on the desktop to the website directing it to open in 32 bit IE everytime.
