Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Open DWF inside Internet Explorer 9
3 REPLIES 3
cakitzmann
2798 Views, 3 Replies
I have an issue with Internet Explorer 9 and Design Review 2012 on a machine with WIndows 7 64bit.  When I try to open a DWF file it asks me what I want to do.  Open, Save, or Save as.  Then it asks me to Open, Save or Cancel down at the bottom of my window.  When I click on open it opens the file by actually opening Design Review program and not inside the browser.  Can this be fixed?
3 REPLIES 3
okstate
in reply to: cakitzmann
I am having this same problem. Did you ever find a fix for this issue? The plugin works fine after I install it but after I reboot the machine it does exactly what you mention.  If I uninstall and reinstall it will work again until I reboot.
cakitzmann
in reply to: okstate
I have not found a solution.  I have gone back to using IE8 unitl I or some does find a solution.
okstate
I found a work around for this problem.  It seems like it is a firewall related issue but I'm really not sure what it is specifically.  When I opened up the firewall completely it worked fine.  I found the workaround to be running the website in 32 bit Internet Explorer instead of the default 64 bit.  I just made a shortcut on the desktop to the website directing it to open in 32 bit IE everytime.
