style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">Shawn
I am publishing from the Sheet Set Manager. All of the Named Page
Setups are valid in the all of the drawings (since they are
numerous).
The title block has one word "REVISION" that rotates. Its
the only word that does it, and only when selecting publish to dwf from the
sheet set manager.
Feel free to contact me if you need any additional
information. The email address is below.
Matthew Anderson,
PE
anderson at jaseng dot com
edit: From what I can tell, removing
all of the unused layouts in drawings or named page setups did not have any
effect on the dwf output. Edited by: Matt.Anderson on Oct 12, 2009 4:26
PM
In the meantime, the only known solution is to plot the problematic sheets individually, as you have found. In some instances, removing the problematic files from the sheet set, and then re-adding them has solved the problem. In other instances, deleting the DWF PC3 file, and recreating it solved the problem. Please note that these suggestions are not guaranteed to work as they have only solved the problem in a few instances. The only definite solution is plotting the sheets individually.
Thank's Shawn for your help.
Matthew Anderson, PE CFM
