I wonder if you would be kind enough to offer us some guidance with regard to deploying this application in a multilingual environment. We have a client who requires if for their users in Germany , Spain Finland ,Ireland ..etc .I know it is available for download in different languages ? Ideally we would like to deploy just one package to all countries. From what I have read on your website I suspect we may need a separate package for each language/country, I don’t think the software can automatically align itself with the OS language or allow the user to switch between languages . Can you confirm that ?
You can create your own setup controller for design review.
To know what you have to call in which order check the setup.ini, there you can find all actions that are done through the normal installer.
If you want to combine different language versions, check which prerequisites are language independent, then create a "multi language" package.
What you can do also is to use patch software to reduce also the package size for different languages.
We did this last year for design review 2013 (En-De-Es-Fr-It-Jp-Ko-Po-Pt-Ru-Chs) and true view 2015 (En-Fr-Jp). The overall package size was 1.5 GB.
regards
Markus
