I've just started using Autodesk design review 10. I'm trying to use this to open pdf's in order to add comments, stamps etc, and then print this to pdf and return it to an applicant (I know this is a little convoluted!).
The problem is that the pdf image gives a scale for A3, however sometimes the pdf appears to have been created as an A4 sheet (probably using AutoCAD) so that when I use the measurement tool, the scale is off. I have no permissions on the pdf and cannot receive the plan as a DWG.
Is there any way I can tell Autodesk Design review that the image size is A3 (short of checking the properties and then printing to pdf as an A3 and starting again.)?
I'm really stuck, previously I've printed, measured & marked, scanned and sent back to applicant and I'm hoping Design review can save me time and paper!
Many thanks
