Design Review
Design Review
huanton
Message 1 of 9 (1,604 Views)
Line looks thicker when zoom in
1604 Views, 8 Replies
05-07-2012 10:45 AM
Gentlemen:
Please advise if there is a way to setup in Autodesk Design Review so the line and dimensions could be look the same when it zoom in.  Please refer to a screen shot for more detail.  Now it looks thicker when zoom in.
Huan Ton
pendean
Message 2 of 9 (1,593 Views)
Re: Line looks thicker when zoom in
05-08-2012 04:46 AM in reply to: huanton
Not enough details: are you viewing a DWF or DWG? Who created the DWF? Can you share it, the image is not informative beyond showing a symptom, but you want the cause addressed.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
huanton
Message 3 of 9 (1,589 Views)
05-08-2012 06:49 AM in reply to: pendean
I created it, I am a CAD Adminstrator at Anemostat Products.  My Engineering manager requested that the lines and dimensions must look the same when zoom in on Autodesk Design Review as  it does on Autodesk Inventor. I do not see any features control the line weight on Autodesk Design Review.  If you do please advise, thanks.
Huan Ton
huanton
Message 4 of 9 (1,580 Views)
05-08-2012 02:00 PM in reply to: huanton
Anyone can advise me with this please! Thanks
Huan Ton
pendean
Message 5 of 9 (1,578 Views)
05-08-2012 03:39 PM in reply to: huanton
You'll have to ask in Inventor forum how to create lines in PDF that all look alike: in AutoCAD, what you describe is either a plot style table setting or an LWEIGHT setting that needs to be removed before the viewer gets a hold of the file.
An Autodesk Viewer does not alter a file's settings, it only views what was created by the file supplier: how did you do that in the first place is what you need to change.
huanton
Message 6 of 9 (1,571 Views)
Re: Line looks fat when zoom in-Autodes Design Review-NOT AUTOCAD OR INVENTOR
05-09-2012 08:49 AM in reply to: pendean
Thanks pendean,
Can you or someone help me how to set up in Autodesk Design Review so the line can look thin still when zoom in.
Please refer to attachment for more detail.  It is in DWF format not in dwg or idw.
If Autodesk Design Review does not have this feature, please advise too.
Huan Ton
andrewiv
Message 7 of 9 (1,515 Views)
06-27-2012 06:18 AM in reply to: huanton
We have this same issue, and would like to know if there is a fix or not.
Inventor Professional 2014 SP2
Vault Professional 2014 SP1
Windows 7 64 bit
Member
BIMTIM
Message 8 of 9 (1,499 Views)
07-12-2012 04:26 PM in reply to: andrewiv
dwf, like pdf is effectively a print/plot file. So the lineweight is set to the page.
You cannot 'turn off' line weights in ADR. This has been requested by me from Autodesk. Will have to wait and see...
Meanwhile, <ctrl>5 will turn off line weights in adobe reader/acrobat
Distinguished Contributor
RNDPIS
Message 9 of 9 (1,392 Views)
08-18-2012 05:17 AM in reply to: BIMTIM
Line thickness works upon the base file Line Weight settings. So when you create the dwf you need to set the line weight setting of that file (Revit/CAD).
