Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
JT import failed
1 REPLY 1
879 Views, 1 Reply
JT import failed
I can't open the file in the Design Review 2013 with import JT plugin. (The file is attached in zip format). The Design Review just show the error messsage: "Error occurred while loading the JT file. The JT file failed to be read."
Any help would be appreciated.
Jiří
1 REPLY 1
zalant
I realize that this thread is old, but I recently had a support case which dealt with this issue of using the JT Import Add-in for Design Review.  The add-in does not appear to be able to open any JT files which are version 9.0 or higher.  Anything lower than that, I've been able to open in Design Review 2013, including the file attached to the OP's first post in this thread.  I'm not sure why it didn't work in that instance.
Zac Travis
