I believe the Autodesk DWF Viewer and DWF Composer use the same class ID, so
HTML pages that reference the ActiveX Control can be satisfied by either
product. In short, users who already have either the Autodesk DWF Viewer or
DWF Composer can view your web pages without having to install anything.
"John Schmier (Autodesk)" wrote in
message news:40c89bc0$1_3@newsprd01...
> Composer is actually an Active-X control, so the answer to your question
is
> yes. The API's are about the same as ADV 4.1 so you can use the same API
> documentation to code Composer as you can ADV. Try going here for the API
> documentation
> http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2418019
> "gneff" wrote in message
> news:11517996.1086885993110.JavaMail.jive@jiveforum2...
> > VoloView comes with a nice little ActiveX control than can be embeded in
> an application or web page.
> > Does anyone know if Composer comes with a similar control that views not
> only dwf but raster formats as well.
