Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
How to set such properties to 3d object ?
2 REPLIES 2
361 Views, 2 Replies
Sorry ,maybe this question should not post to  this forum .and I am lack of experience and limited capability.
First, have a look at the attached DWF file .
It was  downloaded  from BEYOND THE PAPER site.
Open it in the autocad design review and click on some 3d object , object  properties would show . as :
Author,                     garding
Designer,                  garding
Manufacturer,           Standard
Part Number,             Fork-Brace
Part Type name,        Modeling
Physical,
Accuracy,                Low
Area:,                       34.686 inch^2
Material:                    ,Default
Volume:                    4.642 inch^3
I found those objects are not block .
When I click some object in autocade 2009 , I find only these properties : general \geometric figure\3d  Effect.
Thank advance .
2 REPLIES 2
"That model was done in Autodesk Inventor - not AutoCAD. You can get some massprop information in AutoCAD, but not as much as in Inventor. If the author had actually assigned material (like steel) rather than leaving as default - there would be additional information."
thank you !JDMather  Contributor
SilviaCao
Thank you for your questions.
In Inventor, select a part, right click mouse, and select “iProperties…” in the pop-up part iProperties dialog, we can set the properties, which will publish to DWF file as object properties.
Please let me know if you have any further questions.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
