Design Review
Design Review
Active Member
sinm
Message 1 of 3 (549 Views)
How to programmatically select objects
549 Views, 2 Replies
08-13-2012 02:59 AM
Hi!
Can't figure out how to programmatically select a group of objects in a ECompositeViewer so they will be highlighted somehow? Or maybe i can somehow colorize them just how TRANSPARENT command works?
Active Member
troup
Message 2 of 3 (447 Views)
Re: How to programmatically select objects
09-20-2012 05:22 AM in reply to: sinm
I would like to know how to do this too. Any suggestions autodesk admins?
I think it would also be very useful to get all the code examples that are embedded within the windows .chm help file up on a web page somewhere. Copying code out of the windows help viewer is a right pain and loses all formatting.
Cheers
Active Member
troup
Message 3 of 3 (442 Views)
09-20-2012 06:21 AM in reply to: troup
I got this working in javascript with help from the following article:
http://dwf.blogs.com/beyond_the_paper/dwf_programming/page/2/
You can also control the selection set programmatically. First call IAdContent::CreateUserCollection to return an empty IAdUserCollection. You can then add to it the IAdObject interfaces of those objects you want selected. Once complete, you can “set” the IAdContent::smileysurprised:bjects(ObjectType::smileyfrustrated:elected) property to your collection to effect the desired selection."
I translated this to the following Javascript:
var MyCollection = ECompViewer.Section.Content.CreateUserCollection();
MyCollection.AddItem(objectYouWantToSelect);
ECompViewer.Section.Content.Objects(1) = UserCollection;
//Replace objectYouWantToSelect with a reference to your object
//The API uses Magic numbers 1 = selected
