When I open a .dxf file in Desgin Review it only birings in a 8 X 11.5 piece of the part. I do plan on using Design Review to make Tile sections so that I can print templates on my inkjet printer.
My objective is to bring in a DXF file that is too large for my printer and Tile it and print the tiles after I previrew the expected results. Hopefully I will be able to over lap the parts a bit.
Bill J.
Solved by pendean. Go to Solution.
Update: I saved my dxf file in AutoCAD as a DWF and the entire file will open now in Design Review but when I try to print I can not select individual tiles.
dear,
i can't open dxf file in my gerber software v8.1. pls give me solution how to open dxf file
ADR is not a dwg or dxf viewer: it just uses DTV to translate to a DWF using default settings. That's why you only got a partial, and always will.
What tiles in your DWF? you provide no usable info for remote assistance, that's why yuour post has languished for over a week.
