How to compare dwf files via API?
API documentation generally explains how to do it, but my procedure raises an error.
DWF files are generated in AutoCAD Mechanical 2011 by DWF6 ePlot.pc3.
Any suggestions? Thanks in advance
IAdMarkupEditor3 markupEditor = (IAdMarkupEditor3)DwfViewer.MarkupEditor;
IAdComparator Comparator = (IAdComparator)markupEditor.Comparator;
string file1 = @"D:\DWG\file1.dwf";
string file2 = @"D:\DWG\file2.dwf";
Comparator.Compare(file1, "Model", file2, "Model"); //Exception
Thank you for reporting this issue.
We had logged a defect ADROTW-1700 against this issue. We're considering to fix it in further releases.
