Thanks for this. I found your suggested solution and it has worked for me as well. The only issue i now have is that the file size of the PDF copy is about 10 times larger than it was before I selected the Bitmap option.
I reduce the dpi to 300 and reduced the colour quality and this helped - significantly reducing the file size but the quality was still OK.
Thanks again.
Hi, is it possible to permanently select "Turn Data into Bitmap before printing" so that I do not have to constantly go in and select this option every time I want to print (pdf or hard copy).
