Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
File Types DWF, DXF, DWG and DGN
6 REPLIES 6
dbantawa
14342 Views, 6 Replies
Which file types out of DWF, DWFx, DXF, DWG and DGN can Auto Desk Design Review open?
Is it true that AutoDesk Design Review can only open DWF and DWFx file formats?
As per the documentation, DWG TrueView can open DXF and DWG files. I also read that DWG True View can convert DWG into DWF format. How about DXF file format? Can't this be converted into DWF format? The goal is to leverage Auto Desk Design Review to read files of all types where possible.
Any help is appreciated.
Thanks.
Dipendra
Tags (1)
6 REPLIES 6
pendean
in reply to: dbantawa
FAQ for ADR:
http://images.autodesk.com/adsk/files/design_review_2012_faq_customer_v4.pdf
First paragraph and bullet points on TVs webpage:
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
Download both apps (ADR and TV) and explore more, nothing like hands-on experience while you wait here for replies.
dbantawa
in reply to: pendean
Thanks Dean for responding.
I had gone through the faq doc and the url for DWG TrueView, before posting the question. You confirmed that whatever artifacts I was looking are the only ones available.
I had few more questions as below:
  • How about DGN file? Can either of the app open files in this format?
  • I tried to convert DXF file using DWG TrueView to DWF format with no luck. Maybe I am doing something wrong. Does anyone else have this issue or is it just me?
Thanks.
Dipendra
Liust
Thank you for your questions.
1. If you already installed AutoCAD or DWG TrueView, you can open directly the DWG or DXF file in ADR.
2. If you want to open the DGN file in ADR, please download and install the plugin from this site:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13635915&linkID=9338138
Please let me know if there is any other problem.
-Sting
SQA Engineer
PSEB-GE-ACRD PSEB
SmithG_NZ
in reply to: Liust
Which Plugin? I cannot see any that tout DGN as an option.
pendean
in reply to: SmithG_NZ
You are three years too late for this thread, and that old link.
ADR development stopped in the year 2012.
ukdxb012
Have you considered installing Bentley View for free DGN viewing? If I recall ADR 2013 could only open 2D DGN's, not 3D.
Also I'm pretty sure the Plugin was included in later versions but as mentioned previously, development for ADR 2013 has stopped. I could be wrong...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
