Which file types out of DWF, DWFx, DXF, DWG and DGN can Auto Desk Design Review open?
Is it true that AutoDesk Design Review can only open DWF and DWFx file formats?
As per the documentation, DWG TrueView can open DXF and DWG files. I also read that DWG True View can convert DWG into DWF format. How about DXF file format? Can't this be converted into DWF format? The goal is to leverage Auto Desk Design Review to read files of all types where possible.
Any help is appreciated.
Thanks.
Dipendra
FAQ for ADR:
http://images.autodesk.com/adsk/files/design_review_2012_faq_customer_v4.pdf
First paragraph and bullet points on TVs webpage:
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
Download both apps (ADR and TV) and explore more, nothing like hands-on experience while you wait here for replies.
Thanks Dean for responding.
I had gone through the faq doc and the url for DWG TrueView, before posting the question. You confirmed that whatever artifacts I was looking are the only ones available.
I had few more questions as below:
Thanks.
Dipendra
Thank you for your questions.
1. If you already installed AutoCAD or DWG TrueView, you can open directly the DWG or DXF file in ADR.
2. If you want to open the DGN file in ADR, please download and install the plugin from this site:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13635915&linkID=9338138
Please let me know if there is any other problem.
