Reply From: Scott Sheppard - Autodesk
Date: Mar/10/05 - 17:53 (CST)
Re: DWG viewer hijacks drawings.
Autodesk feels that DWG is its proprietary format. SO we think the
association should be associated with our software. Most users want AutoCAD
when they double click a DWG. We have an example here of just how much they
want it - this user doesn't even want another Autodesk product to take it
away. With this is mind, AutoCAD grabs the DWG association back every chance
it gets. With 6 million users out there, many of whom have no interest in
learning how to configure a file extension to a particular application,
Autodesk is doing them a favor. The odd thing is that this user, and I did
this too, installed the DWG Viewer on my system even though I already had a
genuine copy of AutoCAD 2005 on my system. It will happen somewhat, but it
is not the normal 80% use case. I agree that the DWG Viewer should not grab
the association. The problem is that the DWG Viewer is a copy of AutoCAD
OEM, and as a copy of AutoCAD, it is doing the AutoCAD thing.
I put DWG Viewer on my system because it loads MANY times faster than Mechanical 2005. I don't JUST do drafting, so I don't keep M2k5 open all the time. As a result, if I want to look at a drawing, I want a FASTER way of doing it than using full-blown Autocad. Vanilla Autocad might be faster, but I don't even have a working profile set up for it. I use M2k5 exclusively. What I would like to see is for DWG Viewer quit hijacking the file associations, and an object enabler for M2k5 released.
Jerry
