Design Review
Design Review
Active Member
0 Kudos
Post 1 of 4
DWG Viewer Balck and White
141 Views, 3 Replies
07-16-2004 03:31 PM
DWF Composer has a sub application that is the DWG Viewer which allows you to publish to DWF.
The DWG Viewer application needs two additional functions
1) Display on screen in Black and White
2) Publish in Black and White
If these two functions are included into DWG Viewer - then it would be reasonable to not maintain Voloview as a viable product - otherwise - Autocad has defeated much of the purpose of the DWF exercise and engineers like me will simply go back to directing the drafting personel to issue the drawings in adobe acrobat. Is this what Autodesk is intending to happen?
*Jeffrey Klug \(Autodesk, Inc.\)
Post 2 of 4
Re: DWG Viewer Balck and White
07-16-2004 05:12 PM in reply to: Jeff Holloway
PDF is a nice publishing format, if that's all you need. "Jeff Holloway" wrote in message news:1107083.1090017092415.JavaMail.jive@jiveforum2.autodesk.com... > DWF Composer has a sub application that is the DWG Viewer which allows you to publish to DWF. > > The DWG Viewer application needs two additional functions > 1) Display on screen in Black and White > 2) Publish in Black and White > > If these two functions are included into DWG Viewer - then it would be reasonable to not maintain Voloview as a viable product - otherwise - Autocad has defeated much of the purpose of the DWF exercise and engineers like me will simply go back to directing the drafting personel to issue the drawings in adobe acrobat. Is this what Autodesk is intending to happen?
Active Member
0 Kudos
Post 3 of 4
07-19-2004 08:58 AM in reply to: Jeff Holloway
It is nice - but I like to have engineers mark up in Voloview - but for DWG Viewer to replace Voloview - you need a 'View in Black and White' button and a 'Print in Black and White Button'. Autodesk has to consider that the users of DWF Composer are not draftmen - if they were - they would use Autocad would they not? Did Autodesk simply miss this? Will it be out in a future edition?
*David Metcalf
Post 4 of 4
08-02-2004 10:12 AM in reply to: Jeff Holloway
Use print settings with monochrome pen table. If your plotter is black output why use color pen tables? "Jeff Holloway" wrote in message news:8210774.1090252721897.JavaMail.jive@jiveforum2.autodesk.com... > It is nice - but I like to have engineers mark up in Voloview - but for DWG Viewer to replace Voloview - you need a 'View in Black and White' button and a 'Print in Black and White Button'. Autodesk has to consider that the users of DWF Composer are not draftmen - if they were - they would use Autocad would they not? Did Autodesk simply miss this? Will it be out in a future edition?
Post to the Community
New Post
