There is some problems around vb.net and the DWF Control (You are using the
DWG control, not DWG Composer as the subject states correct?). In most
cases if you create the VB.NET project and then add the control, Save it and
close it. When you re-open the project everything works well. Can you try
this, if you can get that far).
If not, please provide me with the following information:
1) Do you have all the patches and service packs installed for .NET
2) What OS are you using
3) Provide me with the exact steps on how you are creating the project and
adding the control to it prior to lockup. Do this only if the above
recommendations do not work.
John.
"Iain" wrote in message
news:15750147.1087546190269.JavaMail.jive@jiveforum1.autodesk.com...
> Iam trying to develop an application in VB.Net and trying to use the
Autodesk DWF Viewer Control. When I apply the control to the to a form it
seems to lock the system, I cannot get any properties for the control, and
my keyboard seems to lock.
