Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DWFX file contents
3 REPLIES 3
charanyajeeva
621 Views, 3 Replies
DWFX file contents
Hello
Has any one converted the dwfx files to a zip file and did a research on its contents like the xml tags. I am working on that and i need to place an image on a dwfx file.
I have converted the jpg file to dwfx and imported the file by creating a catalog in symbols tab through Autodesk design review. I was able to add an image this way through autodesk interface. Now i need to modify the xml  tags internally to place an image. I compared the file using which i added the image through interface and tried to add image through XML tags. But could not succeed . Can any one help me with this.
Charanya
3 REPLIES 3
Kalicy
in reply to: charanyajeeva
Thank you for your qestion.
We don't suggest you modify dwf/x file package directly. Why you want to do this? Could you tell me your request in details?
Kalicy Zhou
SW Engineer
PSEB-GE- ACRD PSEB
Kalicy Zhou
SW Engineer
PSEB-GE- ACRD PSEB
charanyajeeva
in reply to: Kalicy
I am actually into a project that is supposed to sign bulk dwfx files and place a image on the  signed file  . So rather signing individual files i need to sign bulk documents by modifying xml tags in dwfx files which through some coding language could be accomplished.
Charanya
Kalicy
Thank you for your feedback.
ADR (Autodesk Design Review) currently doesn't support this function.
Kalicy Zhou
SW Engineer
PSEB-GE- ACRD PSEB
